Bimmerfest - BMW Forums - View Single Post - 18d timing chain maintenance
Old 10-30-2018, 02:55 PM
Yukoner Yukoner is offline
Mein Auto: 2011 328i x-drive
Originally Posted by timgray View Post
If a person drives very little you still need to change the oil. Water can get in the oil from humidity and condensation as well as combustion byproducts and fuel.
I have changed the oil on cars that sat a year and had a total of 4 miles put on them. But I lived where it is high humidity and had wide temperature swings. I have a friend that has a car in Airizona Desert that changes the oil every 5 years in his barely driven show car.
Personally with todays oils, a yearly oil change is a good idea if it's barely driven and in any place where humidity can cause condensation inside the motor.
This is kind of in-line with what I figured
Not even sure if -40 degrees is cold anymore ?
