Bimmerfest - BMW Forums - View Single Post - How tolerate the ABS can be for different tire size
Old 07-09-2019, 11:10 AM
Dabizness24 Dabizness24 is offline
Mein Auto:
I just had this problem with my 2006 760li. I had put a staggered 20 inch set on my car with 245/35/20 in the front and 275/40/20 in the rear. My abs, parking light, and traction control fault light all came on within a block of getting the tires mounted.. after doing research it appeared that the abs speed sensors were likely reading the rotation of the front and rear tires at two different speeds due to the front tires being smaller they rotate at a faster rate. I decided to change my front tires to 245/40/20, my problem went away.
