PSdZData FULL Requests (Programming Firmware)
Fxx-/Ixx-/Gxx-series
765K views 10K replies 4K participants last post by  Adalbert_77
#1 · (Edited by Moderator)
Hello,
I have version 57.3
Is there a newer version?
What is the newer version?
What does it give over the older version?
Most important, is it needed for a 2016 M3?
#54 ·
Hi
Got the psdzdata v 58.2.
Using the necessary components to run e-sys. (launher prem)
Updated 3 days ago and changed my target in e-sys launcher to F31 (from F11). 3 days later I'm able to change back to F11 (2 is minimum). But now I do not see any targets in connection dialog in e-sys, all empty. I've checked for the dist folder in the mainseries/f10/****/odx/ folder - it's there. I'm outta talent. Help :)
#56 · (Edited)
E-Sys Launcher has nothing to do with E-Sys Connection Targets. Something is wrong from your "update". Make sure psdzdata is in c:\data\psdzdata (not c:\data\psdzdata\psdzdata or any other location.
#57 ·
Hey Shawn,
Can you please send me a link to newest E-Sys_Setup_x_xx_x_.exe, newest ESysLauncherPremiumSetup_xx.msi, newest psdzdata?
Thanks,
sunagawa
PM sent.
#62 · (Edited)
PM sent.
As for your retrofit, that all depends if your hardware will require Flashing ECU's or not, and that I have no way of knowing.
#98 ·
