Hi I have been looking at ways to display whatever i want on the screens in my 2005 730i lci.
I recently found the wiring diagram for the "Video module, analogue and digital TV: E60, E61, E63, E64, E65, E66, E70, E71, E90, E91, E92, E93"
Links to the pages: https://www.newtis.info/tisv2/a/en/e92-325i-cou/repair-manuals/52-seats/1zzikjt
https://www.newtis.info/tisv2/a/en/...-audio-navigation-information-systems/24Ioyei
I have the Hybrid video module Type: DRIVE. since I have the rear entertainment system with digital and analogue TV with the Navigation, Night vision and DVD-Changer. With video in motion coded for the front MMI
Where I found the Pin assignment for connector X18804, 18-pin. There there appear to be video inputs on
pin 17: FBAS wire earth for external video source (via AUX-in connection)
The only pinns that seem to be used in my car are the ones for the navigation and the DVD-Changer.
The only mention of this that I can find on the web is in this thread: http://www.bimmerfest.com/forums/showthread.php?t=563704
Where It was not awnsered if one can connect an external video source to it.
So my question is if ANYONE know if it's possible to use it and if so if there is any coding required do do so?
Update: it has been confirmed that the AUX in on pin 8 and 17 is present and can be activated by sending the right most bus command to it. However there's still no easy practical way to switch to it.
- DVD Changer (pins 3 & 11)
- Night Vision (pins 1 & 10)
