Bimmerfest - BMW Forums - View Single Post - Overheat problem
Old 10-26-2019, 06:25 PM
BabyUnicornTaco BabyUnicornTaco is online now
Mein Auto: 2008 X5 4.8i E70 Sport
Originally Posted by MikeMcD View Post
Hi my name is Mike I have a 1999 328i that is overheating. I have replaced the thermostat for the engine and transmission also the radiator and upper hose. There is no more leaks but it still overheats. It has green antifreeze in it. Is bmw coolant a must and could this be a sensor. I'm not sure where to go from here. Please help!!!
You would be best to post this in the E36 section. You need to scan it with a BMW scanner to check for codes. You may also have a hidden menu to access engine temperature to see if it is really overheating. Green coolant is fine. Hopefully itís not super old coolant. Is your coolant level good?
Sent from my iPhone using Bimmerfest mobile app
2008 X5 E70 4.8i M-Sport
2008 550i RPI Exhaust, RPI Ram Air
