Bimmerfest - BMW Forums - View Single Post - 35d oil leak diagnostic
Old 09-12-2019, 03:21 PM
sunny_j's Avatar
sunny_j sunny_j is online now
bmw addiction
Mein Auto: X5d
the oil coming from the charge pipe is blow by from the turbo and it's normal. mine was leaking so bad I was loosing 3psi of boost. What I did was I took ATM's 335 charge pipe and only used the turbo and intercooler connectors.Then I cut off the factory connectors and used ATM fittings and cut down the orange boost pipe to fit
I would also change this gasket because it tends to leak 13717799839
for #2 I would start by changing the gasket
2012 X5d | Deleted & BRR Tuned | DWR TCU Tune | 10.25" Android 8.1 Screen
Build Log
https://www.bimmerfest.com/forums/sh....php?t=1290337
