Bimmerfest - BMW Forums - View Single Post - Used 2014 428I advice
Old 07-06-2019, 01:30 PM
banglenot's Avatar
banglenot banglenot is offline
Mein Auto: 2007 530i; 2007 328 xit
If you spend all your time in FL, you might consider a RWD version. AWD has a lot of extra parts and complexity.
Also, be aware of problems with the timing chain assy on N20 engines. Failures on some have destroyed the engine. BMW has a timing guide update, but you should do your research on N20 problems and confirm to your satisfaction that the motor is reliable. Engine was upgraded after Jan-Mar 2015 build date.
2007 328xiT
2007 530I
2003 325XI (gone)
2004 530I (gone)
2001 530I (gone)
BMW CCA Member 15+ Years
