Bimmerfest - BMW Forums - View Single Post - Idrive software update fixed error codes?
Old 12-30-2019, 04:23 PM
germans germans is offline
Mein Auto:
Originally Posted by Zeichen311 View Post
Thanks...as noted, that only applies fixes and improvements (such as support for newer phones) to the car's communication with Bluetooth devices. It does not alter the user interface and will not clear or correct any fault conditions, so you still have some problems to diagnose.
You said 2012 335i but did not mention the body style: Coupe or sedan? If the former, that would be an E92, not an F30. You have fault codes for the blower motor voltage; there was a recall for the blower-motor wiring that affected many E90s. I forget whether that extended to the E92 but if this is an E92, it's worth a check.
BMW recalls web site: https://www.bmwusa.com/safety-and-emission-recalls.html
Its the sedan, so its the newer F30 style. All of the recalls have been done. BMW shows zero recalls now.
