Bimmerfest - BMW Forums - View Single Post - Ideas on draining hydraulic fluid from Z4 ?
Old 04-14-2019, 09:09 PM
filtercoffee filtercoffee is offline
Mein Auto: 2007 Z4 3.0i
iirc i do not think you can access any of the stuff you want to unless you remove the whole top assembly
btw there's another way which involves only removing the rear "aluminum c-channel" which joins the rear of the soft top and the trunk area. However, it's still a large effort, and requires you to be able to move the top manually, so you can lift the c-channel up.
https://www.zpost.com/forums/showthr...1215892&page=2
and
https://www.bimmerforums.com/forum/s...ving-roof-DONE
At the end of the day, any way you do it, it's a PITA.
