Bimmerfest - BMW Forums - View Single Post - Ideas on draining hydraulic fluid from Z4 ?
Old 04-14-2019, 09:26 PM
Andyz4 Andyz4 is offline
Mein Auto: 2006 Z4 3.0si
Originally Posted by filtercoffee View Post
Pulling the red hoop pulls on a lever which pushes a bypass button on the hydraulic pump, which allows the fluid to bypass the pump with no resistance. So I highly doubt the fluid is the issue.
Let us know if pulling the red hoop a bit more doesn't fix it! Maybe have a friend pull the hoop while you pull the top.
I agree, you may have a stuck bypass valve. If so, can be fixed without removing top. Google topic for more
