Bimmerfest - BMW Forums - View Single Post - Strut and shock replacement on 2003 540 M-Sport.
Old 06-15-2019, 04:08 PM
Santaclaus4 Santaclaus4 is offline
Mein Auto: Two 2003 540i Msport's
It's my project car so I don't "need" to keep it totally stock. I'd like to keep it close to stock to keep it simple. The shocks and struts that are on it currently are totally worn out. I noticed it when I was replacing the front and rear suspension arms and ball joints. The struts have oil leaking and running down the whole assembly. The rear shocks have an oil smudge at the top so they are just starting to leak.
With all the new parts and new tires (and cooling system), I finally felt it was safe enough to actually drive. The shocks and struts are so worn out the car rode like a 1970's Chrysler. Lumbering and floaty.
I don't want to replace the springs, just the dampeners and I want it to be as "plug and play" as I can.
2003 540i M-sport
If you put cheap parts on your car, you'll soon have a cheap parts car.
The law doesn't determine right from wrong. They are unrelated.
