Bimmerfest - BMW Forums - View Single Post - What is safe oil tempearture to push F30 N20/N26 engine?
Old 10-07-2019, 12:25 PM
namelessman namelessman is offline
Mein Auto: bimmer
Originally Posted by Michael Schott View Post
What is the tensioner mechanism like? I picture a mechanical device with some sort of spring. If this is the case, there's no temperature sensitivity except under extreme cold.
Tensioner is spring loaded, but some posts(in this and other enthusiast forum) mention it is also hydraulically actuated with oil pressure. It can be true that the engine may not even start without the oil pump gets enough pressure, but this is no tech doc(at least not found by online search) to explain that.
My N26 timing chain(and plastic piece) has a slight snag while cold, but solid tight after a drive, so operating temperature appears to tighten the whole mechanism.
Hidden menu says "cold" oil and coolant was 27C this morning. My question is, does engine on already has the correct operating condition such that timing chain is at correct tension for moderate pushing(e.g. merging)?
https://www.ecstuning.com/b-genuine-...yABEgLdN_D_BwE
