Bimmerfest - BMW Forums - View Single Post - DIY: Windshield Washer RESERVOIR Leak Fix
Old 04-05-2010, 06:47 PM
cn90 cn90 is offline
I don't know about E60.
Use realoem.com to cross-check part numbers.
If you can change tire, you can do this except that you also need a jackstand to be safe.
They can charge one hour because: jacking up, tire removal, remove fender liner.
Take the reservoir to rinse it (not needed but since you are there, you may as well rinse it).
Then-re-install.
Not that hard if you want to do this.
