Bimmerfest - BMW Forums - View Single Post - 96 z3 remote keyless-entry security system only 3 chirps
Old 09-12-2011, 06:45 PM
2.3z3 2.3z3 is offline
Mein Auto: Z3
As has been said before you don't need to put anything in the switch just follow the wires from the switch and you will find a connector just unplug the connector. It works fine with the switch just unplugged you only need to put something in to trick it into thinking the radio is there if you leave it plugged in. The switch is unplugged on the 2 Z3's I own and they work fine.
