Bimmerfest - BMW Forums - View Single Post - Oil Life Monitor
Old 05-20-2019, 09:51 PM
Dave 20T's Avatar
Dave 20T Dave 20T is offline
Super Moderator
Mein Auto: 320i (F30)
Originally Posted by chris.luurtsema View Post
I keep noticing during startup that the next service is in 9000 miles.
(oil is the next service due in the menu list this followed by a service check in 27k)
I have put about 1300 miles on the car since the oil change and the monitor has not reflected a change from the 9000 initial count down. Is this normal?
It is normal. What seems to happen is that it stays at a high number, say 9000 miles, for a long time. Then it drops to 8000 miles or so. When it is around 2000 miles, it drops like a rock.
In other words, slow countdown at first, then speeds up too fast.
Originally Posted by Wolfus Aurelius View Post
Which reminds me to ask: How does BMW's computer figure the OCI? Is it by algorithm based on cold starts, city vs. highway driving, temps during short trips, etc. -- or does it actually test the oil?
There is no chemistry lab in the engine compartment. It's not even resistance to electrical current or how well a float floats up.
I believe, but am not certain, that after 2000 liters of gas (about 500 gallons) is used, the oil life monitor indicates it's time to change oil. So a lot of cold weather, short trips will use up gas and result in a lower oil change interval. A moderate temperature and 100% long highway trips will have good fuel economy and a long oil change interval to 500 gallons.
Bimmerfest is a wealth of information!
TPMS sensors from BMW are VDO or HUF/Beru, but are not the same even though frequency is the same.
https://www.bimmerfest.com/forums/sh...d.php?t=976197
Step by step instructions when a hood release cable needs replacement. https://www.bimmerfest.com/forums/sh...d.php?t=981724
SIB 11 13 15 oil filter housing for the F30 - metal since mid-2013 and can be retrofitted without charge
https://www.bimmerfest.com/forums/sh...d.php?t=951692
