Bimmerfest - BMW Forums - View Single Post - 760 hpfp diy
Thread: 760 hpfp diy
Old 11-05-2015, 01:53 PM
Rick in Yuma's Avatar
Rick in Yuma Rick in Yuma is offline
Mein Auto: 05' 760li,94' H1,08'Smart
Check the fuel pipe valve on the fire wall, three fuel lines run to it. The one closest to the outside of car, is leak line. The other two are close to each other on the same side of the valve. Pull the leak side to see how much fuel is coming out when car is running. It should be little or none. The valve could be leaking and filling the vent lines back up with fuel..
