Bimmerfest - BMW Forums - View Single Post - Post-transmission fluid change problem
Old 04-05-2020, 06:13 AM
scottalexander scottalexander is online now
Mein Auto: 2010 bmw 528i
The habbyGuy transmission story is inspiring. Here's why.
This BMW forum is priceless, but what this forum doesn't have is Knowledge Management organization.
For example, we all use RealOEM and without it working on the vehicle would be so much more difficult if not impossible.
Look at how RealOEM is defined into clear sections so you can go right to the section you need, figure out how the parts all fit together, and start ordering parts.
It would be valuable for this forum to have similar sections.
For example, a ZF transmission section.
Are you doing XYZ transmission job today on your ZF 6HP19?
If so, make sure you do this:
1.
2.
3.
4. and so on
By the way, make sure you DON'T do this:
1.
2.
3.
4. and so on
Some might say these work plans have already been compiled on the forum.
With all the spectacular knowledge and experience we have on the forum, the forum is just not 'categorized' like RealOEM to increase the margin for success when we do maintenance.
