Bimmerfest - BMW Forums - View Single Post - WOW! Further consequence of failed thermostat.
Old 03-06-2019, 03:51 AM
Doug Huffman's Avatar
Nuclear engineer
newTIS.infobeta
Home / BMW E70 X5 xDrive35d SAV / Repair Manuals and Technical Data / 11 Engine / 11 65 Charger with control /11 65 020. Damage on the exhaust turbocharger due to obstructed oil supply lines
Originally Posted by NewTIS
Caution!
If the engine does not heat up or only heats up very slowly because of a defective thermostat, this can result in premature or repeated damage to the exhaust turbocharger. Always check the coolant thermostat and thermostat for the EGR cooling if there is a complaint, and repair if applicable.
https://www.newtis.info/tisv2/a/en/e...rol/1VnYPEyClX
It appears also that some sort of major revision to NewTIS is in progress. The file structure is not so useful, perhaps why I stumbled across this interesting and unexpected caution.
