Bimmerfest - BMW Forums - View Single Post - Spring Retaining Clips?
Old 01-16-2020, 03:59 PM
twh twh is offline
Mein Auto: '06 530xi 6sp
For the electrical connectors, in a pinch, you could bend up a paper clip and use it. Or, for either electrical or coolant, go to the hobby shop and get some wire of the right diameter and bend it the way you need it. You could also go to a pick your part junk yard anc clip off the connector you need. The one I've been to locally charges $10 per connector. The coolant spring is also sold separately by OEM and VW, MB, Audi...as i recall it is sized by the hose inside diameter, with 32mm being the most prevalent. You can find them on Amazon. Perhaps the electrical clips are out there too.
