Bimmerfest - BMW Forums - View Single Post - Bad press on run flats?
Old 07-18-2017, 06:02 PM
luckstr luckstr is offline
Mein Auto:
Originally Posted by imtjm View Post
Huh? You are telling me that America's Tire (e.g. Discount Tire) repaired three punctures on a single run flat tire? That goes against every tire manufacturer, U.S. Tire Manufacturers Association (USTMA), Rubber Manufacturers Association (RMA), and even America's Tire own policy and guidelines.
BFGoodrich: 1 repair
Bridgestone: 1 repair only if 15 psi maintained
Continental: does not recommend
Dunlop: 1 repair
Firestone: 1 repair only if 15 psi maintained
Goodyear: 1 repair
Kumho: 1 repair
Michelin: 1 repair
Pirelli: does not recommend
Yokohama: does not recommend
If you didn't have runflats you would have had something else to compensate would you not (e.g. spare, donut, sealing kit, AAA)?
As someone mentioned, if you did not experience pressure loss, your run flats did not perform any differently than a non-run flat tire.
Just spoke with someone at Americs's Tires and they recently received "permission" from Pirelli to do a one time repair on their run-flats
Sent from my iPhone using Bimmerfest mobile app
