Bimmerfest - BMW Forums - View Single Post - 95 325i bad DME
Thread: 95 325i bad DME
Old 04-26-2019, 06:09 PM
spyderg0d spyderg0d is offline
Screamin demon
Mein Auto: 1995 325ic
Yes 95 come with a silver label ews2 dme. But you can use a red label dme the same to become ews1. So, you can go about checking door locks and junk by locking and unlocking all of them. You can test the fuel pump by jumping the pins on the fuel pump relay in the fuse panel.
You can see if the dme is sending voltage to turn on the fuel pump relay. If your posative all those are good, besides the dme not swnding a signal, double check your ews bypass. I mever had to cut any green wire in my cars, bit i did have to cross the 2 large wires at the module to gain cranking. Theres also the gear selector switch for park i think, the brake pedal safety switch i think.
