Bimmerfest - BMW Forums - View Single Post - 335i questions
Thread: 335i questions
Old 05-08-2017, 09:00 PM
josh783 josh783 is offline
Mein Auto: 335i
Originally Posted by bimmer765 View Post
I've found a 2010 335i with 70K miles. Took it out for a test drive and it ran great, but the engine had a cylinder 1 misfire when we got back
after it was warmed up. Also the a/c was blowing hot air, is it common for the evaporators to leak on these? I have a bmw scanner from ecs tuning
and it only came up with two codes, one for the cylinder 1 misfire and another was a low power code for the instrument cluster. If it was low on freon
would there be a code for that?
I just got my 335i back from bmw, had a misfire in cylinder 5. Was told could be injectors, plugs or fuel filter. Turned out to be stuffed camshaft, valves and lifters with a $7k bill. [emoji35]
Sent from my SM-G920I using Tapatalk
