Bimmerfest - BMW Forums - View Single Post - 335i questions
Thread: 335i questions
Old 05-09-2017, 04:31 AM
fxrs1955 fxrs1955 is offline
Mein Auto: 2011 335is
Originally Posted by bimmer765 View Post
I've found a 2010 335i with 70K miles. Took it out for a test drive and it ran great, but the engine had a cylinder 1 misfire when we got back
after it was warmed up. Also the a/c was blowing hot air, is it common for the evaporators to leak on these? I have a bmw scanner from ecs tuning
and it only came up with two codes, one for the cylinder 1 misfire and another was a low power code for the instrument cluster. If it was low on freon
would there be a code for that?
Find an indy you can trust and have him check it out before you buy?
