Bimmerfest - BMW Forums - View Single Post - 335i questions
Thread: 335i questions
Old 05-09-2017, 09:47 AM
Porando Porando is offline
Mein Auto: 2011 335i, 2004 X5 4.4L
Originally Posted by bimmer765 View Post
I've found a 2010 335i with 70K miles. Took it out for a test drive and it ran great, but the engine had a cylinder 1 misfire when we got back
after it was warmed up. Also the a/c was blowing hot air, is it common for the evaporators to leak on these? I have a bmw scanner from ecs tuning
and it only came up with two codes, one for the cylinder 1 misfire and another was a low power code for the instrument cluster. If it was low on freon
would there be a code for that?
"Also the a/c was blowing hot air, is it common for the evaporators to leak on these?"
It appears that way.
Couple years ago when I was about to run out of manuf warranty, I went to dealer to have evaporator cleaned as it started to smell a bit from AC..
SA told me that they will do the test for the evap leak as they've already replaced several with leak... And couple hours later, he confirmed that indeed evap leaks and it will be replaced - and this would be 2 days job because the whole dashboard and center console have to be removed.. they have cooling agent leak detection device.
So i hope that replacements are more reliable.
