Bimmerfest - BMW Forums - View Single Post - E84 engine air filter replacement
Old 11-21-2019, 08:55 AM
dooferorg dooferorg is offline
Mein Auto: 2013 BMW X1
Yea, it's clips around it but you'll likely want to undo the bolts of the part that holds it to the chassis so you can manipulate it to get the housing/shroud apart. Good time to check to see if there's any debris in there - I shop-vac'd mine out and wiped with damp paper towel before reassembly.
