Bimmerfest - BMW Forums - View Single Post - Heater cable adjustment on 2002 Z3
Old 10-26-2019, 11:59 AM
Randy Forbes's Avatar
Randy Forbes Randy Forbes is offline
Investigative Tinkerer
Mein Auto: ///Motorized Vehicles
Originally Posted by Z34TB View Post
Had to replace the control unit on my Z3 but now can't get it to change to heat. How do I get to the other end of the cable where it adjusts damper? The know turns easily so I suspect it came loose at that end.
See if you can find what you need here, though I recommend going back to the home page, entering the last seven (7) characters of your VIN to get model-specific information.
You *might* get enough access from the rt footwell, but I expect you'll have to remove the glovebox to get proper access (that info is in the TIS too).
https://www.newtis.info/tisv2/a/en/e...ater-controls/
Randy Forbes
1957 Austin-Healey 100/6 Wine Red
1961 McCulloch R1 go-kart Screaming Yellow
1999///M Rdstr Cosmos Black our first BMW
1999///M Coupe Estoril Blue Eurosport Twinscrew S/C
2001///M Rdstr Steel Gray
2016 X5M Mineral White Metallic/Beige Dinan STG II (716hp/702 Lbs Ft)
