Bimmerfest - BMW Forums - View Single Post - HELP! Stranded,,,X1 won't start
Old 06-23-2018, 07:00 PM
JimmyX1 JimmyX1 is offline
Mein Auto: BMW X1
Originally Posted by camshaft1964 View Post
I had a similar experience two weeks ago and it turned out to be the ground strap going from the frame to the engine it was green and fell apart in my hands while I was removing the old one. It is under the panels so you will have to remove them on my 2012 I had them off anyway so I could get it into neutral before it was towed home.
Sent from my iPhone using Bimmerfest
Thanks for reply, my mechanic so far has said battery won't charge up to 50% so is starting that the battery is toast. Was your battery indicating such that it wouldn't take charge and immediately at the time of your failure was your battery very hot?
I will pass on the information. Appreciate any further deatils on location. Appreciate. Thank you.
