Bimmerfest - BMW Forums - View Single Post - Signs of a failing ignition switch?
Old 04-11-2009, 12:55 PM
QSilver7's Avatar
Mein Auto: 2006 X5 4.4/2013 650ix GC
New Ignition Switch fixed all the electrical gremlins
Originally Posted by QSilver7 View Post
Although these electrical gremlins are occurring on my 97 E38...the E39 can be afflicted with these odd/mysterious electrical gremlins as well. This is the reason I'm posting the video I made on the e39 forums I frequent as well as the e38 forums. I ordered a new ignition switch and it will be here next week. If I'm wrong...then I guess I'll look like a big fool!
It started with the DSP control unit...it went blank at the beginning of this week. Then mid-week, the airbag light illuminated on the dash, then the rear sunshade started moving real slow, then stopped working.
Then the MLF steering wheel buttons stopped illuminating and when I went to blow my horn...it didn't work. I then remembered that if you pull down the sun visor and open the cover to the mirror and odd things happened...the culprit is usually the ignition switch (yes, odd connection). I even mentioned this back in Oct/2007 after reading about it on one of the e39 forums: http://www.bimmerboard.com/forums/posts/430961
I know that the sun visor test sounds odd...so I made a short video this evening after work just to show how unbelievable the connections are of the components that are affected by the ignition switch. And no...it is not a prank (that's why I waited until after April 1st).
You can see the steering wheel move up/down when I open the mirror cover on the sun visor, and the interior lights fade on/off...and the radio shut off:
Okay, got a chance to tackle the ignition switch this morning in the E38...and as you can see in the NEW video...all the previous issues have disappeared and everything works correctly now.
It took about 1 hour to do the job, not because it was difficult...but taking the time to disassemble and reassemble stuff, making sure you put stuff back correctly, etc...you always drop a screw, or need to go get another tool to do the job etc. On a scale of 1-10...this is probably a 2 or 3.
Here's the video that shows everything is back to normal after replacing the switch:
Q {BMW CCA Member #191509}
2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 2013 F06 650ix Gran Coupe` (Black Sapphire) 1/13 mfg date
(SOLD)
97 740iL (Arctic Silver) <<~>> 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White)
https://www.bimmerforums.com/forum/attachment.php?attachmentid=637911&d=1538398374&thumb=1&stc=1
