Bimmerfest - BMW Forums - View Single Post - Build Log: M57 X5
Old 09-24-2019, 08:13 PM
ucsbwsr's Avatar
ucsbwsr ucsbwsr is offline
Mein Auto: E61
Originally Posted by 2010xdrive35d View Post
Scratch that... I'm going after this first. I was under the hood tonight and my lines look like yours. Instead of replacing them, why not just delete.
Two questions...
1. Where did you get your delete kit?
2. Did your CEL come on?
It's important to distinguish the difference between the vac lines and "deleting" as they are not the same thing. You can delete emissions related stuff from the vehicle but you still need to replace the vac lines if they are in need.
1. My EGR valve delete pipe is from Bimmertune
2. Yes, there are some codes and the CEL light but no limp mode and the X5 performs as it should. I had my OEM EGR valve plugged in and tucked to the side in the engine bay. This is a temp solution until I am fully deleted. IMO better engine health > CEL light.
N54 Powered M5 Wagon:
- M5 Driveshaft, M5 LSD, M5 Axles, M5 Brakes
- M5 Front End, M5 skirts, M5 Mirrors, M-Tech Rep Rear
- KW V3, RD Sport Sways, UR Strut Braces, Forgestar F14 SDC
- Manual Swap, MFactory SMFW, Spec Stg 3+ Clutch, Shiftteck SSK
- EOS Port Injection Manifold, Fuel-It: Stg 2 LPFP +Ethanol Sensor
- N54B30, JB4, Hexon RR550s, Custom Y-Pipe Inlet, AR DPs, 3" Exhaust, VRSF 7" IC, ER CP, Tial BOV, RB PCV, BMS OCC
E39 540iT:
- OEM Style 167, KW V1
- E38 Contour Seats
