Bimmerfest - BMW Forums - View Single Post - Rollover Control module
Old 11-07-2016, 08:55 AM
HerbP HerbP is offline
Super Moderator
Mein Auto: 05 645Ci, 14 750 M-Sport
You would need a copy of WDS to get the detailed wiring diagrams that are not in INPA or DIS. If you run the ECU test in the ROC module (SZM) I think, you should be able to reset the module. ISTA/D would probably have everything you would need.
