Bimmerfest - BMW Forums - View Single Post - BMW E70 X5 - DIY and How-To Thread
Old 07-17-2014, 11:04 AM
lpcapital lpcapital is offline
Send a message via AIM to lpcapital Send a message via MSN to lpcapital Send a message via Yahoo to lpcapital
Mein Auto: Wasp & Duc
I figured it may help to start indexing some of the DIYs and how-to to help new member navigate the website and hopefully cut down on the repeating questions
I encourage everyone to use this thread to point out relevant DIYs and How-to which I will then collect and update the initial threads: I'm really looking for contribution from everyone to make this useful (I don't want it to be MY thread, hopefully it can become OUR). I recommend everyone to refrain commenting or starting a new DIY here: it's best to comment each DIY in it's original post or by creating a new post for a new DIY. This is just for indexing purpose.
MAINTENANCE
Cabin filter replacement
Air filter replacement on 35d
Spark plugs
Tire wear and wheel alignment
DRIVETRAIN
Seal on power steering cap
Rear self leveling airbag replacement
Diagnosing diesel urea/SCR metering unit (post #26)
Engine partition, corroded injectors & fuel lines
X5 35d P205B - repair DEF level sensor
X5 35d - replace throttle body (P0638 and P2621)
INTERIOR & EXTERIOR
Driver side door pull
Airbag SRS cover swap
Resetting sunroof
Emergency brake (EMF) switch replacement
Alternative front license plate bracket
ELECTRICAL
NCSExpert coding
Final Stage Resistor / Blower Regulator Replacement
Rear entertainment screen repair
Battery replacement & registration
Replace headlight vertical aim adjuster motor (xenon headlight)
Upgrade gasket of the rear light on the tailgate
RETROFIT
OEM Trailer hitch installation
OEM Trailer brake installation
Aero kit installation
