Bimmerfest - BMW Forums - View Single Post - F30 tire advice please!
Old 06-26-2019, 03:59 PM
John in VA John in VA is offline
Mein Auto: '74 tii / E28s / '03 530i
Your current set-up is something that should be avoided - mixing tire types. As you're in Europe, your tire choices will no doubt differ from those here in the USA. Do you need winter tires all year, or would all-seasons suit your needs? More expensive tires can have better quality control, roll better & balance more easily. Larger wheels are typically heavier, as are the tires for them. Are your current wheels true/round? Bent rims can result in poor ride quality, as well as worn suspension parts. Then there's the whole run-flat vs. non-run flat decision - many here will say the best thing they ever did was get rid of the original run-flats.
Look in the research & advice section of Tire Rack for info. You can see the tire ratings in the different categories. Find a tire that performs like you desire in your price range. Then see if it's available to you. Good luck!
https://www.tirerack.com/tires/revie...surveyComments
Lots of info here, too: https://f30.bimmerpost.com/forums/fo...play.php?f=423
___________
BMW CCA #30375 - National Capital Chapter
1974 2002tii
1986 535i
2000 328i
2003 530i
2006 330ic ZHP
2015 228i M Sport
