Bimmerfest - BMW Forums - View Single Post - Need help with location of the fuse boxs and overview of fuse positions for 528i?
Old 10-11-2011, 10:13 PM
I looked at my 2002 525i glovebox today to find fuses #1 to #45:
IN ROOF PANEL OF GLOVEBOX:
1 = 30A, Windscreen wiper
2 = 30A, Headlight cleaning system, Windscreen washer system
3 = 15A, Horn
4 = 20A, Passenger comp/trunk lighting, Windscreen washer system
5 = 20A, Sliding tilt/roof
6 = 30A, Outside mirror adjustment, Central locking system, Window lift
7 = 30A, Cigarette lighter
8 = (empty)
9 = 15A, Air conditioner, Heated washer jets
10 = 30A, Passenger seat adjustment
11 = 7.5A, Servotronic
12 = 5A, Immobilizer
13 = 30A, Driver seat adjustment, Steering column adjustment
14 = 5A, Engine control
15 = 7.5A, Diagnosis plug, Engine control
16 = 5A, Light module
17 = 10A, ABS, Automatic stability control
18 = 5A, Instrument cluster
19 = 5A, (empty) Electronic damper control
20 = 7.5A, Air conditioner, Heated rear window, Heater, Tyre pressure control system
21 = 5A, Anti-glare inside mirror, Driver seat adjustment, Garage door opener
22 = 25A, Fuel pump
23 = 7.5A, (empty) Heater, Rear centre arm rest
24 = 5A, Instrument cluster, Shifting gate illumination, Tyre pressure control system
25 = 7.5A, Multi-information display, Radio
27 = 30A, Central locking system, Window lift
28 = 15A, (empty) Transmission control, diesel
29 = 30A, Central locking system, Outside mirror adjustment
29 = 30A, Window lift
30 = 25A, ABS
31 = 10A, ABS, Automatic stability control
31 = 10A, Fuel pump
32 = 25A, Active seat, Electric seat heating, Roller sun blind
34 = 10A, Heated steering wheel (empty)
35 = 5A, (empty) Rear A/C blower
36 = (empty)
37 = 5A, Immobilizer
38 = 5A, Horn, Shifting gate illumination
39 = 7.5A, Charging socket, Courtesy mirror illumination
40 = 5A, Airbag, Instrument cluster
41 = 5A, Brake light, Light module
42 = 5A, Airbag
43 = 5A, (Telephone), (On-board monitor), Radio, (Rear Washer) (Rear washer pump)
44 = 5A, Multi-function steering wheel, MID, Radio, (Telephone)
45 = 7.5A, Roller sun blind
IN TRUNK BATTERY COMPARTMENT:
46 = (empty)
47 = 20A, (empty) Additional heater, independent heater
48 = 5A, Anti-theft alarm system
49 = 30A, (empty) Air suspension
50 = 7.5A, (empty) Air suspension
51 = 30A, (empty) Rear cigarette lighter
52 = 30A, (empty) Cigarette lighter (AUS)
53 = 7.5A, Central locking system
54 = 25A, (empty) M5 Fuel pump
55 = 20A, (empty) Rear washer, Rear washer pump
56 = 30A, (On-board monitor), (CD changer), Radio, (Navigation system)
57 = 10A, (Telephone)
58 = 10A, (On-board monitor), (Telephone), Radio, (Navigation system)
59 = 20A, (empty) Trailer socket
60 = 50A, (empty) Elecronic damper control
61 = (empty)
62 = (empty)
63 = (empty)
64 = (empty)
65 = (empty)
66 = 40A, heated rear window
UNDER PASSENGER SIDE CABIN AIR FILTER:
BEHIND GLOVEBOX (look from underneath):
75 = 50A, Auxiliary fan
76 = 40A, Heater blower
ABOVE BATTERY POSITIVE TERMINAL:
100
101
102
103
104
105
106
UNDER PASSENGER SEAT:
107 = 50A, SAS airpump Special Fuse: BMW PN 6113836590
108 =
109 =
110 =
111 = ignition switch?
112 =
113 =
114 = ignition switch?
ID:	296807   Click image for larger version
