Bimmerfest - BMW Forums - View Single Post - Fxx-/Ixx-/Gxx-series help please with INPA
Thread: Fxx-/Ixx-/Gxx-series help please with INPA
Old 12-08-2019, 11:14 AM
blink_ blink_ is offline
Car Nut
Mein Auto: 750LI & Opel Astra Turbo
I have got the files, followed the instructions, but when i run istagui as administrator, nothing happens, but it creates a log file like this
2019-12-08 18:11:51 INFO [T] ISTA: [1] ConfigSettings.ConfigSettings() - called
2019-12-08 18:11:51 INFO [T] ISTA: [1] ConfigSettings.StoreAndLogChangedValue() - Change configuration "BMW.Rheingold.OperationalMode" from "" to "ISTA_PLUS" (read from "Configuration file").
2019-12-08 18:11:51 INFO [T] ISTA: [1] ConfigSettings.ConfigSettings() - OperationalMode is ISTA_PLUS
2019-12-08 18:11:51 INFO [T] ISTA: [1] ConfigSettings.StoreAndLogChangedValue() - Change configuration "BMW.Rheingold.Logging.RotatingTextWriterTraceListe ner.FileName" from "" to "" (read from "").
2019-12-08 18:11:51 INFO [T] ISTA: [1] ConfigSettings.StoreAndLogChangedValue() - Change configuration "BMW.Rheingold.Logging.Directory" from "" to "..\..\..\Logs" (read from "Configuration file").
2019-12-08 18:11:51 INFO [T] ISTA: [1] ConfigSettings.StoreAndLogChangedValue() - Change configuration "BMW.Rheingold.Logging.Directory" from "..\..\..\logs" to "..\..\..\Logs" (read from "Configuration file").
2019-12-08 18:11:51 INFO [T] ISTA: [1] App.StartIstaServices() - Try to start ISTA Services host ...
2019-12-08 18:11:51 INFO [T] ISTA: [1] IstaProcessStarter.Start() - called.
2019-12-08 18:11:51 ERROR [T] ISTA: [1] IstaProcessStarter.Start() - Failed to start ISTA operation. Reason: "System.TypeInitializationException: The type initializer for 'BMW.Rheingold.CoreFramework.CoreFramework' threw an exception. ---> System.IO.FileNotFoundException: Could not load file or assembly 'RheingoldCoreBootstrap.dll' or one of its dependencies. The specified module could not be found.
at BMW.Rheingold.CoreFramework.CoreFramework..cctor()
--- End of inner exception stack trace ---
at BMW.Rheingold.CoreFramework.CoreFramework.get_Debu gLevel()
at BMW.Rheingold.CoreFramework.Log.Debug(String method, String msg, Object[] args)
at BMW.Rheingold.CoreFramework.WcfCommon.IstaProcessB ase`1.Initialize(String[] args)
at BMW.ISPI.IstaServices.Host.IstaServicesProcess.Ini tialize(String[] args)
at BMW.Rheingold.CoreFramework.WcfCommon.IstaProcessB ase`1.Perform(String[] args)".
2019-12-08 18:11:51 ERROR [T] ISTA: [1] App.Init() - Failed to start ISTA: BMW.Rheingold.CoreFramework.WcfCommon.IstaProcessS tartException: Failed to start ISTA operation. Reason: "System.TypeInitializationException: The type initializer for 'BMW.Rheingold.CoreFramework.CoreFramework' threw an exception. ---> System.IO.FileNotFoundException: Could not load file or assembly 'RheingoldCoreBootstrap.dll' or one of its dependencies. The specified module could not be found.
at BMW.Rheingold.CoreFramework.WcfCommon.IstaProcessS tarter.Start[TArgs](String pathToIstaProcessFile, TArgs istaProcessArgs)
at BMW.ISPI.IstaServices.Controller.IstaServicesContr oller.StartHost(IDictionary`2 configuration)
at BMW.Rheingold.ISTAGUI.App.StartIstaServices(LogCle aner logCleaner)
at BMW.Rheingold.ISTAGUI.App.Init()
at BMW.Rheingold.ISTAGUI.App..ctor()
