Bimmerfest - BMW Forums - View Single Post - Ordered an M4 today, winter tire question
Old 10-02-2016, 08:30 AM
visi107 visi107 is offline
Mein Auto: 2016 M3
Originally Posted by Stevenym4 View Post
I ordered an M4 cab today with the competition package. The car comes with 255/30/20 tires I believe. I have access to a set of rims and tires from an M3, 5 lug, 120 mm bolt pattern, 17 in. x 7.5 in., 41 mm offset. The tire size is 225/45/17. I realize there is about an inch difference in height which will cause a slightly lower speed to register on the speedometer. My question is will the 17" wheels from the M3 work on the M4 without causing issues with the car and will they fit over the brakes? I did not get the carbon brake package. Got 5.3% off invoice for those who are interested ordered as follows:
As was said previously, the 17's will not fit, has to be minimum 18. In addition to that, not all 18 inch wheels will fit.
Also whatever setup you go with, you want the height, diameter and circumference to be about the same or you will run into issues with the traction control. It's not just about the speed being off. It is recommended that the circumference is within 2-3% of the stock sizes.
2018 F80 M3 CS
My 2016 M3 ED adventure
2013 328i X drive - retired
