Bimmerfest - BMW Forums - View Single Post - auxiliary coolant pump line disconnection or short circuit to B+
Old 08-21-2019, 09:20 AM
Doug Huffman's Avatar
Nuclear engineer
A Diagnostic Trouble Code error number does not identify a broken part to be replaced but identifies a symptom that may be caused by any number of failed components or adjustments to be differentiated amongst by execution of a BMW Test PlanŠ guide through the fault tree.
A Brush-Less Direct Current - BLDC - motor is plenty complicated by itself. It is commanded by Pulse Width Modulated PWM signal from the ECU.
I suggest taking it to the authorized BMW Service Center.
