Bimmerfest - BMW Forums - View Single Post - DIY replacing injectors of 09 X5 35D diesel?
Old 09-29-2015, 10:55 AM
atrandom atrandom is offline
Mein Auto: 2009 X5 35D
Originally Posted by ninja_zx11 View Post
Good find!!
So it means connection from DDE to the junction box is good.right? and problem is only from the junction box to the injector.
Is it possible to visually trace the wires from the junction box to the injector? I think each pair to each injector is twisted.So check if the got pinched and shorted.how long is the wire run from junction box to the injectors?Is there any connector inside the junction box to disconnect the injector wire from the DDE side of wiring?
Its also possible for the wires to get shorted right inside the connector (injector side) due to water problem.You may have to cut one or both wires from the twisted pair close to the injector connector to diagnose the location of short.
The wire should be looks like this. I pull the pic from ebay, not exactly the same but almost. box side looks like brand new so injector side is most possible.
It's going to rain so I have to do it tomorrow.
