BMW Coding and Programming
Discuss coding options and features on your BMW here. |
Coding: Getting Started Guides, Tips, & Cheat Sheets
Big thanks to all the Bimmerfest members that have contributed to this thread. Specifically ShawnSheridan and Tokenmaster stand out for helping to create this thread.
What is Included:
NOTE2: See this thread for Software Links 1. What is Coding: Coding is a bit of a misnomer. Neither any programming language (eg, C++ or Python) knowledge is necessary nor software modified. Instead, an easy-to-use, graphical user interface (GUI) is used to customize settings so a vehicle operates more as the individual desires. This guide will help minimize risks and outline how to reset a vehicle back to factory. If you choose to proceed, approach the task with a clear plan, know the steps, and NEVER guess, clarifying any doubts before you proceed. Many willing forum experts will assist you. 2. Step-By-Step Guides: E-sys Getting Started Documents (Updated 06/07/2017)
At a later time, peruse "User Manual v1.4," as it is more comprehensive & may be confusing or overwhelming at first. VO vs FDL Coding ![]() See Notes on Retrofits ![]() NOTE: "CODE" = VO Coding. "Code FDL" = FDL Coding 3. Connecting To Vehicle:
CAUTION WARNING: Besides initial connection, the following conditions can corrupt ECU's if vehicle & computer communication is disrupted:
4. Helpful Hints & Acronyms:
Coding Made Easier (Cheat Codes in E-Sys Launcher): See Video @1:25 ![]() NOTE1: Use Launcher Pro to sync or manually download latest Cheat Codes from Github. Place in one or more of the following directories:
Make sure to "Review" potential changes before applying because funktions move around and present codes may not be relevant to vehicle.
Sponsored Links | ||
Advertisement | ||
Hello sir.
I've downloaded the latest cheat code from github... can u tell me real quick how to install it? |
Copy the .xml files to C:\Program Files (x86)\TokenMaster\E-Sys Launcher Premium\FDLCodes.
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc. |
Advertisement | ||
Thanks sir. Much appreciated
Helooo, coded my cousin's F10 today and was unable to locate the file for changing i-drive screen to the M emblem, used the cheat sheet but couldn't see it. Is it possibly called something else on other models. Thanks guys.
Also when updating the software on the F10 there was no selection for DME, ICM or DSC. Anyone know why?
If you mean in Flash TAL, maybe these ECU's had no Updates. With each new release, not every ECU receives updated firmware.
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc. Last edited by shawnsheridan; 07-12-2017 at 04:17 PM. |
Thanks again Shawn I will look into it.
Do you guys recommend any places to get an ENET cable?
Problem with coding/Missing cafd
Hello,
Thank you guys for your help in advance. Yesterday, I upgraded my fog lights into Led ones. However, when I tried to code them, in (FEM_ BODY) I was surprised to receive an error message telling me that " file for cafd xxxxxxxxxxxxxx not found" ( photos attached) I checked the other modules, and I found another error message in (ACSM) History of coding: last year I coded 2 things only, M performance logo, and Auto Start/Stop memory. I followed the directions as advised by Shawn, and everything was fine. After some long visits to the dealer because of a noise problem to be fixed under warranty 2 months ago, I noticed that I've lost these too codings; M performance logo, and Auto start/ stop memory. My thought was that the dealer has recorded the car, or reset it to default. I don't know what exactly has been done to the car by the dealer. What do you guys think? and what can I do to solve this problem? here are links to the photos in case the attached ones aren't clear https://drive.google.com/open?id=0By...zQ3RXpoN3FZdTA https://drive.google.com/open?id=0By...2otZG9CZkZFQlU Regards, Albert Last edited by Albert Goodman; 07-20-2017 at 05:25 PM. |
Likely dealership flash programmed vehicle. |
Hello Shawn,
Thx for your help, last year I coded my car with no experience in coding at all. I took the car to the dealer, and seems like they reset it to default. Or updated the software. I tried to code it yesterday, but some files are missing. I posted a thread before this one because I was scared that somethin was wrong with the car, then I did some research and found that I need to update my pasdaza. please help regards, Albert |
Coding: (No Request) Latest Software Links |
Do I have to reinstall PSZD, or just update it? is there any instructions for the update? thx |
Deleted existing psdzdata folder and replace with new version. Do NOT merge old and new.
so, I go to data folder, and delete psdzdata folder only, and paste the new one. would you kindly send me the link to the new psdzdata download, Almaretto sent me the link in the previous post, but I found many files their... |
Thank you Almaretto!! you are my savior!!!!
one last question, is it ok to code the car while engine is running? My battery is a bit old and I don't have a charger. |
Engine should be running, unless coding DME/DDE (Engine ECU).
I did some coding before with engine off
![]() Thanks alot |
Engine is run to maintain battery voltage and provide communication to all ECU's. If you are quick, and do mostly offline coding, then engine does not have to be on. However, you do not want vehicle to auto-shutdown while coding and potentially corrupt ECU's. |
I've made some progress trying to do a little coding on my 328i and have reached the point where I want to backup default. Instructions say engine should be off however everywhere else instructions is suggest keeping the engine on while coding to keep battery power up. In my case during the read of defaults the car just turned itself off (timed out) as the engine was not running. Is there really a downside to running the engine while backing up default settings? Thanks in advance,
And coding backups are worthless. You can reset ECU to factory settings simply by VO Coding it.
#25
I coded the Sport Display on my 2011 F10 535iX. It showed the units of kW for power and Nm for torque. When I floored the car, the torque meter maxed at 400 Nm which is about 300 ft-lb that matches my car's spec. Recently I coded the hp and ft-lb units for the Sport Display. However, when I floor the car, the max torque still reaches the the scale of 400 which now should mean 400 ft-lb. Am I missing something? Or the Sport Display is just imitative?
See More Related BMW Stories |
Forum Navigation | |||||||
Today's Posts Search |
Thread Tools | |
Display Modes | |
