E39 faq - Page 6 - Bimmerfest - BMW Forums
Old 01-14-2017, 02:02 AM
Mrtoad Mrtoad is offline
Mrtoad
Mein Auto: Bmw e39 530i
Originally Posted by Ted Komorowski View Post
I have the same a e39 530i after about a year I got the same problem with the same BMW codes In odbii it is PO174 & PO171. lean codes for bank 1&2. Ran smoke test and replaced the MAF and two O2 sensors did the carb cleaner test to find intake leeks-none. Finely got PO313 code about fuel pressure and replaced the fuel pump. Now I wait I think this will solve the problem. The fuel pump could keep every think going but not enough volume to do it right (would have seen pressure drop under load and 3k rpm)
good luck The center what was removed??? May invalidate everything
The centre box of the exhaust system has been removed and the chap that I got her from said that he had had the car tuned for economy don't make sense to me might as well have bought a micra ***128513; ***128513; a BMW is for the love of driving not economy, OK I shall investigate this further and let you know, I was going to get a new ecu with the scanner giving me the part number lol ***128513;
Old 02-19-2017, 12:33 PM
528iAut 528iAut is offline
Mein Auto: 1996 528i
About the forum here, every thread I look at seem to be registered as a "subscription" and I receive an email when there is activity in the thread, this is very annoying, how do I get rid of this, I dont want all these emails....
E39 528i Steptronic 1996, Comfort seats, Rear sunshade, Focal amplifier and front speakers, Oxford Green.
Old 02-19-2017, 01:00 PM
TheAngryBear's Avatar
TheAngryBear TheAngryBear is offline
Mein Auto: 01 750iL DD74441
Go to your profile page, subscription settings, and click on the applicable options as you desire.
Old 02-19-2017, 01:23 PM
Ok, found the setting so I dont get emails, thank you.
Old 02-20-2017, 12:31 AM
Mrtoad
E39 fault code bank 1 and 2. Permissable limit reached,
Found the fault it turned out to be a bank 1 and 2 oxygen sensors in active replaced both and the fault has cleared cost 50 from. Ebay, nice cheap fix will replace later on with genuine parts. From Germany they are so much cheaper, lol ***128513; ***128513; o
Old 02-27-2017, 03:00 AM
Mrtoad
Fault codes e39 530i
Right guys I have replaced bank 1 and 2 oxygen sensors as the diagnostic said they were in active, it now staits they are active, I now have bank 1 fuel trim limit and bank 2 permissable limit reached, maf live data on idle is between 17/18kg on reving the engine up to 4000rpm the maf live data is peaking at 104kg,and back down to 17/18kg on tick over,, the car runs fine but is a bit juicy I know it's a 3,0l but it should be getting more than I'm getting, any advice is greatly appreciated been looking at you tube video with people cleaning the maf is it worth it, or is it best buying a new one, cheers guys, ***128513;
Old 03-29-2017, 09:20 AM
bigjon2828 bigjon2828 is offline
Mein Auto: 2003 530i E39
Trans fail safe
Old 04-03-2017, 11:43 PM
mariopos mariopos is offline
Mein Auto: bmw e39 2001
pixels
hi everyone, can ypu help me with this check problem, i cant read it
Old 05-20-2017, 07:25 AM
Vlada.Sofranic Vlada.Sofranic is offline
Mein Auto: e39 (520i) e30 (325e)
check control
I guess is "CHECK LOWBEAM LAMPS"
Old 05-20-2017, 07:36 AM
check control
you can download user manuals,and read all errors,page 85,86
http://www.bmwtips.com/OwnersManuals...SportWagon.pdf
Old 08-29-2017, 09:25 PM
rbelton rbelton is offline
Banned
Mein Auto: E39
6 Cylinder Spark Plug DIY Guide:
Oxygen Sensor DIY Guide:
E39 Auxiliary Audio Input Kit DIY
Banned
Mein Auto: E39
Old 02-09-2018, 05:17 AM
wikkel wikkel is offline
Mein Auto: 525i 2001
Originally Posted by chivas View Post
Here's something i think we should all do. start a FAQ since these questions seems to pop up every... oh.. 6-12 days?? here's a start...
What a smashing ride. I had the wonderful opportunity to be chased by a X3 over 100km. reaching 215 on the clock but not a cent more. i begged, i swore, i pleaded -- but the f%^$#kng X3 stayed on my tail. how can I loose this asshole Not true. it was a great experience and i doubt it can ever happen again. Thanks friend. You are a great driver and it revitalized an old senile burnout.
Never do Caledon to Napier again. Wishing you a long and super DRIVE life ! Willy Cape Town 525i 2001. 220k on the clock.
Similar Threads
Why is there more used E39 540's for sale, is there something i don't know? gixxer E39 (1997 - 2003) 53 11-06-2017 08:28 AM
BEST BUY - E39 BMW shop manuals shaftdrive 5 Series DIY 61 08-02-2012 10:23 PM
E46 M3 for a devoted E39 owner? jvr826 1M & M2 27 03-01-2005 11:03 AM
NJ BMWCCA Round 2 Elwood Motorsports, Racing & Track 75 07-06-2004 05:45 AM
Wide Picture from the Bimmerfest run, lookout point mola 5 Series 8 04-16-2003 09:54 PM
