2014 F06 oil - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > F06 Gran Coupe (2013 - 2018)
BMW's entrance into the 4 door coupe segment to go head to head with the Audi A7 and MB CLS
Old 03-18-2019, 11:24 PM
Curbee714 Curbee714 is offline
Mein Auto:
2014 F06 oil
Does anyone with a 2014 650i gran coupe have any problems with the oil?i constantly have to keep adding 2 quarts every so often, about once a month? Some say it's normal because of the Turbo engine, some say 2 quartz is a lot. I still have warranty and the dealer says it happens a lot with the V8 engines but some says it's not normal. Just any feedback would be appreciated, thanks
Old 03-19-2019, 10:18 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Mein Auto: 2006 X5 4.4/2013 650ix GC
Here's some past discussions of the same topic. The N63 & N63TU is used in the f10/f11 5 series, f01/f02 7 series, f06/f12/f13 6 series, and f15/f16 X5/X6 series...so you will see similar issues across all 3:
  1. https://www.bimmerfest.com/forums/sh...d.php?t=848195
  2. https://www.bimmerfest.com/forums/sh...d.php?t=896620
  3. https://www.6post.com/forums/showthread.php?t=1343577
  4. https://www.bimmerfest.com/forums/at...1&d=1553011275
Q {BMW CCA Member #191509}
2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 2013 F06 650ix Gran Coupe` (Black Sapphire) 1/13 mfg date
(SOLD)
97 740iL (Arctic Silver) <<~>> 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White)
https://www.bimmerforums.com/forum/attachment.php?attachmentid=637911&d=1538398374&thumb=1&stc=1
Old 03-20-2019, 10:59 AM
dagoo98's Avatar
dagoo98 dagoo98 is offline
Mein Auto: 2014 BMW 650xi Gran Coupe
Definitely not normal, I've never added oil to my 2014 650 between oil changes. I change my oil every 5,000 miles. Car currently has 22,000 miles and I've had it for 4 years. Bought it with 1,500 miles on it.
Old 03-20-2019, 05:34 PM
Mein Auto:
Thanks guys, just contacted my service advisor and there is supposedly a customer care package for bmw's with the N63 engine. Taking it in to have it checked out because this does seem too excessive for the amount of oil it's consuming. Will update this thread once I find out what happens. Thanks guys! God bless
Old 03-20-2019, 08:06 PM
thebmw thebmw is offline
'Fest Advisor
Mein Auto: BMWs and other fine cars
You don't have the N63 engine. N63 was only for 2012s. You have the N63tu engine and there is no customer care package for that.
Old 03-21-2019, 07:48 AM
QSilver7's Avatar
... just contacted my service advisor and there is supposedly a customer care package for bmw's with the N63 engine. Taking it in to have it checked out because this does seem too excessive for the amount of oil it's consuming. Will update this thread once I find out what happens. Thanks guys! God bless
Ditto above...your model year has the N63TU engine...so you don't fall under the recall program.
And for even more clarification about the N63 iteration of engines...see the list below. There were five N63B44 engine iterations (and six if you count the 4.0 liter N63B40 engine used for the China market) that span from the N63/N63TU/N63TU2/N63TU3/etc that were used in E-G series BMW models. Hopefully the info below will help you understand what you have and where you fall withing the N63 debacle:
Name:	BMW N63 Customer Care Engine Program Recall.jpg
ID:	844747   Click image for larger version
Name:	BMW N63 Engine Iteration Chart.jpg
ID:	844755   Click image for larger version
Name:	BMW N63 Engine Iterations and Model Years.jpg
(SOLD)
Old 05-16-2019, 03:20 AM
Mein Auto:
Well, as for now, I still have the same issue, just did one oil consumption test, BMW topped off my oil and told me to bring it back at a thousand miles or when/if the low engine oil light comes on, it came back on after about 860 miles. Now they are doing a 2nd test, same thing but if it fails again (which is very likely since I don't drive like a maniac and I always have it in comfort mode) they said they would replace the engine. I have read posts on here that this was offered for the N63 engines, has anyone with a N63TU engine had this problem? Looking for more input on what options are available to me. Does anyone know, if they replace the engine, is it the whole engine with transmission? Like a brand spanking new engine with zero miles? What will happen with my mileage odometer if this is the case?!? Thanks in advance.
Old 05-19-2019, 09:57 PM
dagoo98's Avatar
Brand new engine but no transmission. The mileage on the vehicle stays the same, just because the engine has zero miles the rest of the car still has mileage that needs to be accurately disclosed.
Old 05-24-2019, 12:25 PM
bigdog100 bigdog100 is offline
Mein Auto:
I have the N63TU and dealing with the same issue. I have done 3 of the 1k oil consumption test and every time it is in spec of 1 quart per 750 miles. However, at 2000 mile it burns 4 quarts it doesn't make sense and dealer will not do anything because the 1k oil consumption test are in spec.
Similar Threads
E92 N55 Oil level indicator accuracy - Low oil level DetroitP E90/E91/E92/E93 (2006 - 2013) 6 09-05-2018 09:05 AM
Oil burn after oil change samadkins29 F10 / F11 (2011 - 2016) 65 08-15-2018 06:36 AM
Damaged Engine - Faulty Oil Change - Engine Oil Cap insert removed. justinz X5 E70 (2007 - 2013) 7 07-04-2018 09:36 AM
Oil use 2014 535i DProffitt F10 / F11 (2011 - 2016) 4 04-14-2018 10:51 AM
Johnsons baby oil for leather Fifty_Cent The Detail Department 26 01-20-2004 02:49 PM
