Staggered Offset Help - Bimmerfest - BMW Forums
Old 05-16-2019, 05:06 AM
IronRobi IronRobi is offline
Mein Auto: 2011 X5 35d
Looking to put a staggered setup on my 2011 x5.
I know the factory sizing/offset is:
20x10 ET40 Front
20x11 ET37 Rear
Selection with those specs seems very limited (Maybe it's a Canada thing).
I'm looking between 2 almost identical styles of rims.
Braelin BR10
20x9 - ET25 and ET 38
20x10.5 - ET20, ET30 and ET40
Niche Gamma M224
20x9 ET35
20x10.5 ET35
My instinct is telling me to go with:
20x9 ET25
20x10.5 ET30
This will give more inner clearance and extend both front and back by an extra 2mm. Not having a staggered setup right now, I'm not sure if that extra 2mm is going to cause any clearance issues.
Looking for advice from people with experience.
Old 05-16-2019, 05:50 AM
1bad540's Avatar
1bad540 1bad540 is offline
Mein Auto: E65 750i Sport,C5 z51 e46
the factory offset is already pretty aggressive. Not sure extending even more will look right.
[SIGPIC]
e39 540i sprt, acs type 2's,acs pdls,clrs(sold)
e65 745i sprt,21's aib's acspdls, rf splr(sold)
e46 328i 18" 335spt whls(sold)
c5vette 6sp,z51,2"drp,19"ccw'sshrt shft,corsa exh,dd nav(sold)
e53 X5 3.0, pna rf,,20"4.6rims.(sold)
e65 750I aw, sprt. 21's,acs pdls,acs rfsplr,mtecs,8k hid(sold)
Srt10 VIPER, 19-20" forged,tune,corsa ex,intake.
w221 S550 amg,dia white,20"s63rims
e70 3.5 aw.mtec,20" 214 whls.
e46 M3vert,6spd,19"HRE,bbk,ext,intke
w222 S550 amg, dia white
Old 05-16-2019, 06:13 AM
I'm not sure 2mm will visually make a difference which is why that's my first instinct. I'm more concerned with rubbing.
The other options (ie: ET38/ET40 or ET35) will pull them inwards between 8-12mm which is almost half an inch. That will visually be noticeable, which may not be a terrible thing either if I don't do the extended flares. But then my worry would be more with rubbing on the inside. The rims will have clearance, but will that half inch cause the inner tire to rub?
Old 05-16-2019, 08:57 AM
1bad540's Avatar
is 25 to 40mm 2mm??
[SIGPIC]
Old 05-16-2019, 09:10 AM
is 25 to 40mm 2mm??
Different wheel widths.
20x10 ET40
20x9 ET25
The ET25 on a 9" rim will give 28mm more clearance on the strut side and push the outer edge of the rim outwards by 2mm
ET38 on a 9" rim will give 15mm more clearance on the strut side and retract the outer edge of the rim inwards by 11mm
But now as I'm typing this out I'm thinking it's not really the rim positioning that matters it's more the tire positioning that will affect rubbing. If the rim is 1" narrower, then there probably should be about 1/2" less on each side to keep the tire position in the same spot. By lining up the outer edge of the wheels then the tire will end up sticking out another 1/2".
This is why I need an offset expert, I'm just getting myself confused LOL
Old 05-16-2019, 10:09 AM
Alright I think I found a good calculator with graphs
Fronts:
https://www.wheel-size.com/calc/?whe...cl=30mm&sr=0mm
Rears:
By going 20x9 ET38 in the front, while the position of the rim changes by a lot, the outer position of the tire should only extend by 2mm
By going 20x10.5 ET40 in the rear, the outer position of the tire will retract by 3mm giving 3mm less clearance to the suspension.
I assume the factory setup will allow for more than 2-3mm of clearance in either direction so I'm assuming I should be OK?
Similar Threads
E60 sport staggered, how wide are my wheels? Reino550 E60 / E61 (2004 - 2010) 2 11-14-2015 02:08 AM
style 124 wheels, awd, and offset Bobdobalina E60 / E61 (2004 - 2010) 16 04-16-2015 03:51 AM
SOLD: 18" Style 162 BMW factory OEM wheels & tires STAGGERED E90 335i 330 328 325 Pat_X5 Wheels and Tires 10 06-15-2010 05:54 AM
BMW Hype? - E90's Staggered Tire Sizing ShoeDog E90/E91/E92/E93 (2006 - 2013) 47 02-01-2006 06:37 PM
Offset for 19" staggered wheels on 528i? frdvschvy Tires, Wheels, Brakes & Suspension 3 09-08-2005 08:08 AM
