All the lights on dash and radio is on but won’t crank. - Bimmerfest - BMW Forums
Old 05-14-2019, 07:33 AM
laurag laurag is offline
Mein Auto: 2003 z4 roadster bmw
I have a 2003 z4 bmw and all the lights come on and dash lights come on, radio ect.. all comes on, but the car won’t crank. I replaced battery and starter is good. Can someone please help me figure this darn thing out?
Sent from my iPhone using Bimmerfest mobile app
Old 05-14-2019, 08:12 AM
Clearancediver's Avatar
Clearancediver Clearancediver is offline
Mein Auto: 2004 Z4, 2009 Nomad mc
Possibly your ignition switch. According to posts it is inexpensive to replace and an easy DIY.
Old 05-14-2019, 08:24 AM
Another cause would be the ground strap from engine to frame deterioration to point that starter current no longer able to flow.
Old 05-14-2019, 08:25 PM
Andyz4 Andyz4 is offline
Mein Auto: 2006 Z4 3.0si
Do the headlights dim at all when you try to crank it? If so, check battery cables and terminal connections. If not, try wiggling the key in the ignition as you try to crank it. If it is the switch, Autozone sells them. Easy job to change.
[SIGPIC]
Old 05-14-2019, 11:06 PM
KevinC's Avatar
KevinC KevinC is offline
your average JAMF
Mein Auto: '08 Z4 M Coupé,'16 Golf R
My BST (Battery Safety Terminal) blew 2 weeks ago for no reason whatsoever. It's supposed to blow in a crash where your airbags have deployed. It separates the positive connection that goes to the starter and alternator. Check your battery - you should have 2 positive connections, make sure one of them hasn't separated. That damn part is about $225 and is unobtainium in the US right now - I'm still waiting for a replacement from Germany that hopefully arrives this week.
'08 Z4 M Coupé LM08602
'16 Golf R
'17 Kawasaki Versys 650
Old 05-16-2019, 10:45 AM
keeton keeton is offline
Mein Auto: '07 3.0si
This happened on mine and was the ignition switch. Just to be sure: when you turn it to "start", the lights don't dim and nothing happens. When mine was acting up you could try it several times and it would finally catch.
As others have said, this is a (fairly) easy DIY (look for YouTube videos). The switch can be had for $20-40 (Ebay no-name Chinese), $65 (name brand aftermarket) or $100 (OEM discounted e.g. Pelican).
Old 05-16-2019, 07:25 PM
Juggernaught5 Juggernaught5 is offline
Mein Auto: 2006 Z4 3.0si Roadster
I had the same issue, it was the ignition switch
Sent from my iPad using Bimmerfest
Similar Threads
Radio code help please Toxin99 E36/7 Z3 (1996-2002) 5 06-15-2015 04:01 PM
Dash lights on, radio turns off, headlights really dim. DJ 911 E36 (1991 - 1999) 3 02-07-2012 12:16 PM
SOS need Z3 radio code bMw99z3 E36/7 Z3 (1996-2002) 3 10-31-2011 09:16 AM
Z3 Radio says code debby E36/7 Z3 (1996-2002) 3 10-24-2010 06:50 AM
Radio Revision TSB crowz E46 (1999 - 2006) 0 07-21-2007 09:49 PM
