i3 coding - Page 13 - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > BMW i > BMW i3 I01 (2014 - Current)
The BMW i3 and BMW i8 are the first two cars launch under BMW's new sub brand BMW i. The i3 is an all carbon fiber, all electric vehicle meant for urban mobility.
Old 11-26-2017, 07:27 PM
cbennet1 cbennet1 is offline
Mein Auto: i3
Coding hardware/software
Hi All,
New to this forum. I've used VAG/COM for my Audi S4 but now an acquiring a new to me i3 and want to tweak the usual settings.
I have a MacBook Pro which does not have an ethernet port. Are the Bluetooth or Wifi OBD2 dongles an option? If so, any that are "preferred"? Recommendations on software would be appreciated as well!
Regards,
Craig
Old 11-26-2017, 08:13 PM
shawnsheridan's Avatar
bimmerfest Supporting Member
Mein Auto: 2016 650i GC M-Sport
Originally Posted by cbennet1 View Post
Hi All,
Regards,
Craig
You will only be able to use a USB x LAN Adapter, and a ENET Cable. Software on Mac will need to run in a Windows Virtual Machine.
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
Old 11-26-2017, 09:51 PM
Mein Auto: i3
Thank you for the confirmation. Hardware ordered!
Old 11-26-2017, 09:54 PM
Old 12-20-2017, 05:07 PM
d451d d451d is offline
Mein Auto: i3
I just got my i3 back from the shop after taking it in for the i3 recall. First thing that I noticed other than that all of my coded mods were gone but also that the software itself must have been updated to a newer version. Many of the menus have changed and some items have removed. I've coded my i3 three time before so as soon as I got home I fired up E-sys and started to go at it. After connecting and reading the edu I didn't see any of the modules that I expected to see (ASCM2, BDC_BODY, BKOMBI and HU_NBT) and when I selected the CAFD module and tried to read the coding data it failed. Has anyone else ran into this since taking their i3 in to get the new recall software installed?
Thanks,
dave
Old 12-20-2017, 05:08 PM
Thanks,
dave
You need to update. PM sent.
Old 12-20-2017, 05:09 PM
Almaretto's Avatar
Almaretto Almaretto is offline
Super Moderator
Mein Auto: Test Vehicles
Thanks,
dave
Names do not traditionally change, but firmware on vehicle > computer PSdZ means it is time to update. Self-Service.
Old 12-20-2017, 06:50 PM
czarmar czarmar is offline
Mein Auto: '99 323i
Same here: I got my i3 back from the airbag recall, and saw I needed to update my psdzdata. So I got 3.63.3, but now I don't get any connection options with the new psdz. It just shows a blank screen and my VIN. Do I need to patch something with Tokenmaster's launcher?
Old psdzdata allows connection, new psdz shows blank target connection options.
'99 323i with 292K miles
Old 12-20-2017, 07:01 PM
Extract PSdZData only with 7-Zip or WinRar, and copy PSdZData folder to C:\Data.
Old 12-20-2017, 08:33 PM
Almaretto's Avatar
Super Moderator
That is user error. Make sure you have something like the following:
C:\Data\psdzdata\mainseries\I001\I001-17-11-541\odx\dist
Old 12-26-2017, 05:44 AM
fredlove fredlove is offline
Mein Auto: i3
I bought a little wi-fi plug on Amazon and paid $25 to an app on my iPhone and Im able to code the system from my iPhone. Works great.
Old 12-26-2017, 04:12 PM
You can probably do more with other methods, but BimmerCode app does work, and especially in the default mode (not expert), it's pretty simplistic.
Jim DeBruycker
Old 12-26-2017, 08:11 PM
Mein Auto: i3
Im on a Mac and from what I saw those apps were PC only, so I found a nice option. It did everything I want except I don't see the option to stop the welcome chimes when I start the car.
Old 12-26-2017, 09:10 PM
Almaretto's Avatar
Super Moderator
E-sys is Windows program that can be run natively or in VM.
Bimmercode is IOS or Android.
Old 12-27-2017, 07:49 AM
Mein Auto: i3
Yeah. Thats the app that I used. I should look in the advanced area for the 3 tones to shut off. Any idea what the name of that feature is? Thanks.
Old 12-27-2017, 08:05 AM
Almaretto's Avatar
Super Moderator
Welcome gong, acoustic belt warning, or initial.
Old 01-12-2018, 01:39 PM
Mein Auto: i3
Thanks. Will check it out as soon as I get back in after getting the car back from dealer doing the recall.
Old 07-10-2018, 08:54 AM
flyboy320 flyboy320 is offline
Mein Auto:
Is premium launcher sufficient to code the i3 using e-sys (basic things like legal disclaimer, am radio, etc.) or is pro recommended?
Old 07-10-2018, 09:02 AM
PREMIUM is fine.
Old 07-10-2019, 09:54 AM
friednoodles friednoodles is offline
Mein Auto:
Hi, I'm trying to connect to my 2015 i3 using Esys and an OBD to Ethernet cable but I keep getting a "no zgw available" error. I have v4.16 of PSdZ installed on my computer. Any help would be appreciated.
Old 07-10-2019, 10:01 AM
Run Motor
Make sure Cable is Firm in OBD Port
Disable Windows Firewall / Defender on PC
Old 07-11-2019, 01:54 PM
Christopheri3 Christopheri3 is offline
Mein Auto:
Need some help from any brainy coders out there.
I have changed the steering wheel on my 2017 REX, and the steering buttons are not working. I have tried in Bimmercode 3140 PfLSteeringWheel. and tried F15/F45/F56/F16 and nicht_aktiv. it was set to I01. still not working??? am I not doing it right?
Thanks in advance
ID:	857803   Click image for larger version
ID:	857805   Click image for larger version
Old 07-11-2019, 06:55 PM
Almaretto's Avatar
Super Moderator
Thanks in advance
Are you sure wheel is compatible and connected correctly? Did you try VO coding with E-sys? Check ISTA+?
