Exhaust leak? - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 07-09-2019, 09:51 AM
bmwguy07 bmwguy07 is offline
Mein Auto: e36 m3, 323i,amg 95,
Exhaust leak?
Hello everyone, recently I made a post on a header bolt being stripped. I repaired that with a helicoil but the noise is still there.
I tried to feel any leak around the header while the car was on although I haven’t found anything, I tightened all the header bolt holes and still the same.
The sound sounds like a normal header leak but not seeing or feeing anything
I did recently take the lifters and “cleaned them” (took the middle piston out and clean” I did pump oil through them (to prime) I kinda feel like it might be the lifters? The sound is loud at first start up then quotes a bit down when engine is hot but whenever gas is pushed can hear it . Maybe secondary pump check valve failed ? I will post a video later.
Sent from my iPhone using Bimmerfest mobile app
Old 07-09-2019, 07:20 PM
bluptgm3 bluptgm3 is online now
Mein Auto: 99M32
Did you replace the gasket?
Old 07-09-2019, 08:14 PM
Yes exhaust manifold gasket has been replaced
Old 07-09-2019, 08:46 PM
The more I look into it online I feel like I must have installed the manifold gaskets on wrong maybe backwards?
Old 07-10-2019, 05:37 PM
spyderg0d spyderg0d is offline
Screamin demon
Mein Auto: 1995 325ic
The gaskets dont care what way they go on, as long as they do go on. You have to have every bolt in, and every nut tight. If you have a sap, that takes a gasket too.
If it starts really loud then quiets down, it sometimes symptomatic of a cracked exhaust pipe or the later gaslet leak. Double check 02 sensors are tight as well.
Old 07-11-2019, 05:00 PM
cmybimmer's Avatar
cmybimmer cmybimmer is offline
Registered Non-OP
Mein Auto: 5wagon
Are you sure the leak is coming from the headers? Maybe coming from a loose O2 sensor around the cat? Or maybe even where the muffler connects to the midpipe.
Sometimes when you're listening to sounds from under the car, it's a little deceiving where it's actually coming from since the sound is getting bounced around. Just a thought
-Usama
1994 325is (2006-2010) -- 1989 325i M50 Swap (2011 - 2014) -- 2001 525iT (2018 -Current)
Old 07-11-2019, 10:34 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x3,E30x2, F150
Holy cow, look who showed up!
Hey, 'Sama!
Quotes to live by:
Ken Kanne, Silverhill, AL, Bimmerfest Site Moderator
BMW-CCA #441426
1993 325is M3 clone"Ashlyn"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette";1995 318is"Bebe "; 1985 325e "Hazel Ann"
Old 07-11-2019, 11:12 PM
cmybimmer's Avatar
Registered Non-OP
Mein Auto: 5wagon
Hey, 'Sama!
Hey Ken! Figured id contribute a lil lol
-Usama
Old 08-10-2019, 12:44 PM
Exhaust leak was found. I decided to start simple. Took the secondary air tube out to have a better view. What did ya know your boy forgot to install new tube gaskets that connect to the head.
