Obc reset - Bimmerfest - BMW Forums
E30 (1982 - 1993)
Old 07-11-2019, 12:04 PM
Tateriolo Tateriolo is offline
Mein Auto: 1991 BMW E30 325i CONVERT
Obc reset
Hi all!
My name is Santiago and Im writing from URUGUAY, South America!
I own a 1991 E30 325i CONVERTIBLE which I imported from USA to my country.
I had to replace the battery, so I removed the old one and replaced with a new one.
When I started the car, the "ENGINE OIL" light in the OBC remained on.
So I reset the computer (with the device that you can get on ebay, with the "oil" and "service" reset buttons) and the "ENGINE OIL" lamp turned off
The thing is that since then, every time that I start the engine, none of the OBC lamps turn on (for a couple of seconds and then turn off) except for the "Brake light" one... The labels turn on and then off, but none of the lamps..
If you press the "CHECK" button, they all turn on and off as they should, but not when turning on the engine...
Please correct me if Im wrong, but I strongly believe that when turning on the car all the lamps turned on for a couple of seconds and then turned off, except if there was a problem so then kept on, isnt it the way it works?
What may have happened that now they do not turn on automatically?
Thank you very much for your time!
Kind regards, from Uruguay,
Santiago.
Old 07-11-2019, 10:23 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x3,E30x2, F150
Welcome to Bimmerfest!
No, the check system lights don't come on unless there's a problem except for the brake check light. Your system is working properly.
Quotes to live by:
Ken Kanne, Silverhill, AL, Bimmerfest Site Moderator
BMW-CCA #441426
1993 325is M3 clone"Ashlyn"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette";1995 318is"Bebe "; 1985 325e "Hazel Ann"
Old 07-12-2019, 08:15 AM
Thank you very much for your reply!!!!
I swear that Ive seen the lights turning on and off every time I turn on the car, I need to stop drinking before driving!!!
obc, oil, reset
