Bmw 2006 650i coupe - Bimmerfest - BMW Forums
Old 07-12-2019, 06:28 AM
Mikeuno583 Mikeuno583 is offline
Mein Auto:
Bmw 2006 650i coupe
Has anybody gotten a code 5d8d hydraulic unitump
My 650i coupe battery died when I jumped it I got big abs light on display where time is and brake light and triangle lights on dash before the jump no lights on I connected odb scanner got 5d8d hydraulic unitump everything was fine before the battery jump start I erased the code drove out the driveway same abs light brake light triangle came back on as soon I touched the gas ...
Old 07-12-2019, 04:12 PM
zod zod is offline
Mein Auto: 1987 BMW 535is 2008 E64
A battery problem, like you described, can cause all of your problems. The dynamic drive system is one of the first systems affected. Wiser heads will be along.
Old 07-12-2019, 06:20 PM
HerbP HerbP is offline
Super Moderator
Mein Auto: 05 645Ci, 14 750 M-Sport
Since you had to jump the battery, it is low on voltage. The voltage is critical to the control units, & must stay above 12 volts at all times. Measure the voltage at the jump terminal with the headlights on, & the engine off. If the voltage is below 12 volts, try charging the battery overnight. If this fixes your problem you are good to go, but if the voltage is below 12 volts a battery is probably bad. The alternator should put out around 14 volts.
Since the ABS light is on, check your power steering fluid to make sure it is not low. Pentosin CH-11s is the required fluid, & found at most parts stores.
