2004 bmw x3 3.0L - Bimmerfest - BMW Forums
Old 07-11-2019, 01:58 PM
Marvn Marvn is offline
Mein Auto:
2004 bmw x3 3.0L
Check engine light on showing p0171 and p0174. I replace plugs,fuel filter, disa valve, oxgen sensors but the code keeps coming back. Not sure what else to do.HELP
Old 07-11-2019, 10:12 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x3,E30x2, F150
Welcome to Bimmerfest!
I moved your posting to the E83 forum (X3, 2004-2010) so you can get model-specific help.
Quotes to live by:
Ken Kanne, Silverhill, AL, Bimmerfest Site Moderator
BMW-CCA #441426
1993 325is M3 clone"Ashlyn"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette";1995 318is"Bebe "; 1985 325e "Hazel Ann"
Old 07-12-2019, 05:09 AM
BMWaufKS BMWaufKS is offline
Mein Auto: 2008 X3
1) Clean the MAF, and replace the air filter (if neither are new)
2) Get a BMW-specific code reader such as the Creator C310; there's plenty of double-secret codes.
3) Do a smoke-test to look for vacuum leaks. I hear a very common one on M54s is a cracked intake boot, so if you are very-able you may proactively want to remove, clean, and inspect it carefully for cracks.
Others with M54s will hopefully give you more ideas.
P.S. Soon, make a signature file, for your future posts, with basic info about your X3. See below for an example.
Since 1/2016, restoring a
2008 BMW X3 M-Sport, N52, automatic ("#1")
Modifications:
All stock except dashcam
Since 3/2017, also restoring a
2008 BMW X3 base-model, N52, automatic ("#2")
Modifications:
Dashcam, cargo cover, cargo mat
Old 07-12-2019, 09:51 AM
jeepo23 jeepo23 is offline
Mein Auto: 2008 X3, 6 Speed
Are those not vacuum leak codes?
Old 07-12-2019, 05:14 PM
Mein Auto:
I change intake gasket trottle body gasket air filter pcv system replaced.
Also do a smoke test no leak was found.
Am also experiencing rough idle and rpm Serge.
Old 07-12-2019, 06:13 PM
dukedkt442's Avatar
dukedkt442 dukedkt442 is online now
Anti-Hack
Location: Hudson Valley/LI, NY; Treasure Coast, FL; OBX, NC.
Mein Auto: 2008 BMW X3
Very first thing I'd look at is the rubber bellows in the air intake; M54 is notorious for them. Both banks lean supports that idea. Valve cover gasket is another vacuum leak source. It doesn't seem to be misfiring so you can eliminate misfires as a lean source.
2008 BMW E83 160k+ 2016 Chevy Silverado 84k+
2011 VW Jetta 120k+ 1984 GMC S-15 130k+
1986 Oldsmobile 442 130k on body 200+ on engine
1978 Honda Hobbit 2.6k+ 1961 Cub Cadet Original
1962 Springfield Gem 1965 Jacobsen Chief
1977 Bolens G9 1992 Jacobsen 810
Old 07-12-2019, 07:49 PM
Mein Auto:
Valve cover gasket seems nice and dry
Old 07-13-2019, 12:55 AM
dynagroove dynagroove is offline
Mein Auto:
90% sure you have a vacuum leak somewhere. I purchased a 2004 X3 3.0L last year and had the same codes. There are multiple places that your motor can leak from. I'm going to tell you what I did. I replaced all soft parts on the top end: valve cover gasket + grommets, intake boot, entire CCV system, dip stick tube o-ring, dip stick o-rings, DISA valve rebuild + gasket, throttle body gasket, intake manifold gasket, FI gaskets, vacuum lines, vacuum plugs, other parts I'm sure I'm forgetting. I did a bunch of other work while I was in there, but that's what I did to address the vacuum leak.
Get a scanner. You can get OBD Fusion for $10 for your phone and a $20 LE BT adapter - that's all you'll need for this job. There is a ridiculous amount of information out there on how to fix P0171 & P0174. Spend some time searching and you'll find everything you need.
Old 07-16-2019, 08:39 AM
legalfee's Avatar
legalfee legalfee is offline
Mein Auto: 2004 X3 2.5i 5AT
Old 07-16-2019, 10:14 AM
codog2 codog2 is offline
Mein Auto: 5
I've gotten that code at least three times on my 2005 (200k). First two times - cleaned MAF and it went away. Last time (6 month ago) - needed to replace CCV valve. At the time I was also getting the occasional huge plume of smoke at start up, occasional erratic idle.
Old 07-16-2019, 03:50 PM
Mein Auto:
I did all that but the code still coming back. Am going to change the dip stick oring seal next.
Old 07-16-2019, 08:29 PM
Mein Auto:
What exactly have you done? Please let us know everything that you have done so that we don't tell you to do something you've already done and so that we know what else you haven't done.
From multiple posts, it seems like you've done the following:
"I replace plugs,fuel filter, disa valve, oxgen sensors"
"I change intake gasket trottle body gasket air filter pcv system replaced."
sounds like you cleaned the MAF as well
Have you replace the valve cover gasket and all grommets?
Have you replaced the intake boot?
I'll repeat what I said in my earlier post:
OBD Fusion will not just show and clear codes. It shows you realtime data while the car is running. Fuel trims and O2 sensor performance are important in diagnosing where your car has an issue.
Old 07-16-2019, 10:49 PM
Mein Auto:
I have done everything mention in the msg except valve cover gasket and grommets,dip stick o-ring seal
Old 07-17-2019, 11:36 AM
abscate abscate is offline
Mein Auto: 2006 BMW X3... VOLVO... V
How did you do the smoke test? I once smoke tested my E83, with negative results, spending an hour pn the wrong side of the booster check valve,
I won the Moron Mechanic of the Month, or MMM, award, that year
Old 07-17-2019, 12:03 PM
Mein Auto: 2008 X3
Search Youtube, and for posts/pics (including mine) on here. E.g., with a latex glove on the intake.
Modifications:
Modifications:
Old 07-17-2019, 12:47 PM
Mein Auto:
I used the intake boot
Old 07-17-2019, 06:36 PM
Mein Auto:
Dip stick tube o-ring is certainly a possibility, but there is a far greater chance that it's your valve cover gasket if you haven't changed it in the last 30K to 40K miles. These gaskets basically turn to hard plastic over time. It's a regular maintenance item and is very easy to replace. Don't forget to replace the grommets as well as they are part of the seal. You will also need some gasket sealer for the areas around the VANOS unit. Kits with everything you need are available and there are plenty of how-to videos to explain the process as well.
BTW, OBD Fusion can tell you if you have a large air leak or a small air leak based on what the fuel trim readings are. It can also give you an idea if your MAF is working in the correct range.
Old 07-17-2019, 08:50 PM
Mein Auto:
I have a OBD2 scanner that i used its giving me a vaccum reading of 19-20psi when the vehicle is in park and 12-15psi
Mein Auto:
In gear *
Old 07-18-2019, 04:33 AM
You canít trace a vacuum leak with a gauge. The amount of leak needed to kick out a fuel trim code is very small.
If you monitor the short term fuel trim at idle and at 2500 rpm it will tell you If unmetered sir ( vacuum leak) is happening.
Old 07-18-2019, 05:49 AM
Mein Auto: 2008 X3
The "paint can" smoke tester (some on eBay) is a crude but effective tool for doing the smoke test. Wear PPE, and be safe!
Modifications:
Modifications:
