2016 535i Tires Wearing Out Fast - Bimmerfest - BMW Forums
Old 07-12-2019, 02:42 PM
THDFW528 THDFW528 is offline
2015 528i
Mein Auto: 2016 BMW 530i M Sport
Tires are wearing out fast for my 2016 535i M Sport, any suggestions, thanks in advance for your help.
Old 07-12-2019, 02:48 PM
Krynos's Avatar
Krynos Krynos is offline
Mein Auto: '14 F10 550 & '13 F10 528
Drive slower.
Old 07-12-2019, 02:56 PM
BabyUnicornTaco BabyUnicornTaco is offline
Mein Auto: 2008 X5 4.8i E70 Sport
How many miles on them? Run flats? Time for an alignment?
2008 X5 E70 4.8i M-Sport
2008 550i RPI Exhaust, RPI Ram Air
Old 07-12-2019, 02:58 PM
Jay Arras's Avatar
Jay Arras Jay Arras is offline
Casual Fanatic
Mein Auto: 2007 530xi 6 speed manual
What kind of tires are we talking about? HP Summers maybe? What brand? How many miles?
2007 530xi, Black Metallic Sapphire, 6 speed manual, Sport package, Cold Weather Package, Premium Package, Premium Sound Package, Sirius Satellite Radio, MTech front bumper, Replica Style 166 wheels
Old 07-12-2019, 05:53 PM
Raymond Lee Raymond Lee is offline
Send a message via AIM to Raymond Lee
Mein Auto: BMW and MBZ
I was told by Tire shop guy that all BMW and MBZ tires tend to wear inner side of tire more due to turn radius. I was advised to rotate tire every 3000 miles.
Old 07-12-2019, 06:13 PM
Autoputzer Autoputzer is online now
BMW's (and maybe M-B's) have a lot of negative rear camber (tires tilted in at the top). That causes the rear tires to wear "conically." My F10 spec's are 1.8 degrees of negative camber in the back.
The trick with tire rotation is to have four or eight rotation stints over the life of the tires, so that the tires are in each position once or twice. Every 3000 miles would put 36k mile tires in each position three times. 4500 mile rotation stints would put the tires in each position twice, and save four rotations at a cost of about $25/each. Remember, that tire guy is making $25 for fifteen minutes work.
Old 07-12-2019, 06:26 PM
Since you live in the Sunbelt, you probably don't have AWD ("xDrive" in BMW lingo). Since you have an M Sport Package and probably not AWD, you likely have staggered tires (back tires wider than the front ones). So, you can't rotate your tires, except side-to-side on the same axle. For RWD's, the back tires will wear about twice as fast as the front ones.
High-performance tires don't last as long as "touring" (low-performance) tires. Run-flat tires don't last as long as similar performance non-run-flat tires.
Combining all the factors above together, consider yourself lucky to get 25k miles out of the back tires, and maybe 50k miles out of the front tires.
If you have a square set-up (front and back tires the same size), you'd benefit from tire rotation, getting all four tires to wear evenly and spreading out that rear negative camber induced wear among all four tires instead of just two tires. With a square set-up and high-performance tires, don't plan on more than 35k to 40k miles out if a set of tires.
Keep the pressures where they are supposed to be, and watch for edge wear. Edge wear is a sign of misalignment, specifically the toe (direction the tire is pointed).
Old 07-12-2019, 06:37 PM
Autoputzer
Thank you very much. That is quite educational and helpful. Since I have all 4 tires same size, I will change every 3000 miles. Thanks again.
Old 07-12-2019, 11:51 PM
MunichMark MunichMark is offline
Munich Mark - 2014 535XD
Mein Auto: 2014 535XD (German Model)
Tire Wear - what’s normal ?
To know what abnormal is one first has to know what normal is...
I also run square setup, 245 45 18
First near 20,000 KM's with Run Flats, the usual Conti Contact 3...
Little feedback, steering kickback in hard corners, generally uncomfortable especially with anything higher than min recommended tire pressures...
Normal wear is front outside (especially XDrives) and rear middle (more on RWD). This is with the recommended pressures around 34 PSI front and 38 PSI rear...
When I moved to real tires I can run 39 PSI front and 45 PSI rear with even better comfort, feedback and fuel economy with ~30% less tire cost, much less potential of Rim damage, etc...
Wear is about the same, a little less in front actually depending on driving style...
Suspension is fully adjustable rear on F10's but front Camber is not unless you install Meryle Top adjustable wishbones which really is not necessary unless lowered to the ground - Hey ese
On lowered Cars and especially with 19" or 20" wheels the wear rear moves more inside to the point of very quick cord separation or peek thru near the inner sidewall to tread area if tire pressures under 40 PSI rear. Each tire brand is a little different and web search will find you plenty of Pics as evidence.
As far as general guidance expect about 30,000 miles out of a non run flat square setup if you rotate every season and about 25,000 out of runflats, normal driving and pressures always right.
Regards,
MunichMark
2014 535XD LCI
Euro 313HP
465 TQ @1500 RPM
Alpinweiss - Nappa Mocca
AC Schnitzer 30-30 Springs
18" Michelin Pilot Supersport / PA4 Winter
