325es Restortion - Bimmerfest - BMW Forums
E30 (1982 - 1993)
Old 09-08-2019, 09:30 PM
the325es the325es is offline
Mein Auto: 1986 325es
325es Restortion
Forgive me if I'm doing this wrong as I'm completely new to posting on forums. I'd basically like to document as well as share my restoration that I have started. I am a very experienced collision tech so it should be a good follow if anyone is looking to learn the trade.
Vehicle is
1986 325es
200K Miles
White Exterior
Blue Leather Interior
When I acquired the car last fall the car was not running due to a aftermarket antitheft unit that was installed. I removed that and fixed a ton of wiring BS that was done by the previous owner and we now have a running car. Although not well, Its running and the engine sounds great. Well aside for a misfire issue...Anyways. Nothing I can't work out. Anyways to not ramble on too much. where Im at now, body work has begun. To get everyone up to speed I'm going to post a picture of the car as it stands before restoration started and then I will get a few catch up posts here shortly too. I did not realize I need to have links for the photos I post. Not entirely prepared here. Open to advise and welcome comments if I'm doing anything wrong here.
Hope you all enjoy the restoration!
Thanks!
Drew
Old 09-08-2019, 10:36 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x3,E30x2, F150
Welcome to Bimmerfest, Drew!
You do NOT need to have a photo hosting site to post pictures. You can upload pictures directly to Bimmerfest. Compose a posting and before clicking the "submit reply", look at the additional options box below that. Click the "manage attachments" button, it will open a small window with 6 "chose file" boxes. Click one, navigate to the photo file on your computer that you want to post, click on it and then click the "open" box at the bottom. You will then see the file name in one of the "chose file" boxes. Repeat with the other 5 boxes (or fewer) then BE SURE to click the
"upload" box. Wait until the attachment box tells you that you can close that window or the photos won't post. The files have to be smaller than 500Kb for most photo types. They will appear as thumbnails. Clicking on them will open a full size picture.
Looking forward to seeing your progress!
And this is my 1985 325e!
Quotes to live by:
Ken Kanne, Silverhill, AL, Bimmerfest Site Moderator
BMW-CCA #441426
1993 325is M3 clone"Ashlyn"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette";1995 318is"Bebe "; 1985 325e "Hazel Ann"
Old 09-09-2019, 08:55 AM
Thanks for the Help! and a great looking 85' you have there! goals.
Thats a relief that you can attach a normal image. I tried linking my google images and apparently was not working so I gave up and went to bed. I Have a picture of the car posted now that is of when I brought her home last fall. The evo spoiler was naturally too sexy for my style, so the last few nights I've spent repairing the deck lid so it doesn't have holes drilled in the center of it anymore.
I should be able to post up the process on that this evening and maybe a few other general pictures. She is in rough shape but I think she is worthy. One, being a complete ES its a fairly rare model. (seems like there are lots of fakes) Plus like everyone...Ive just always wanted an E30.
Old 09-09-2019, 09:03 AM
What the heck, Figured I would dive in with a few more recent photos before I head off to school. Basically just some around the car photos. Hope these are all oriented better than the last one. The last photo shows the holes on the trunk lid that need to be repaired. Hopefully after school I will get something up here on the process of that part.
ID:	863945   Click image for larger version
ID:	863947   Click image for larger version
ID:	863949   Click image for larger version
ID:	863951   Click image for larger version
Old 09-09-2019, 10:33 AM
On to the holes on the decklid. First photo kinda shows a good example of what was going on under the aftermarket wing that was on the car. The panel had 4 holes drilled in it for the spoiler to be bolted down through. around each hole there was a fair amount of silicon. once the spoiler was removed I first took a flat razor and scrapped all the silicon off. Then I went over the whole panel with 320 grit basically prepping the whole panel, it gets rid of surface contaminate in the old paint, its easy to get the remaining silicon off of the repair areas and that is what grit I want to prime the car.
second photo
At this point im going to take 80 grit and feather out the repair areas to have some room to work. Im super meticulous when I weld and for this type I even take a file rod and make sure the inside of the holes has a good surface for the weld. Welding the holes up is pretty easy. most of the ****ty experiences I've had with this type of work comes from rushing and distorting the panel. if you can be patient enough to so about one little "zot" at a time and let it fully cool you should be gravy.
Third photo(I think)
Grind you welds down very slowly and avoid the heat! you've come this far. *I finish these with a file once I get them close and if the panel shape allows me to.
Fourth photo,
One coat of Evercoat metal glaze over each repair area. Shape Sanded w/80 grit then 180, then 320 for the final finish. (all 80 grit scratches should be out) I use a powder guide coat between each grit. Pro tip- powdered guide coat is the ****.
Ill try to get a little more detailed with these posts in the future. I finished this work on the car a week or so ago and therefore...alot trying to get crammed into just one post.
pro tip 2-while waiting for welds to cool clean the trunk!
ID:	863979   Click image for larger version
ID:	863981   Click image for larger version
ID:	863983   Click image for larger version
ID:	863985   Click image for larger version
Old 09-10-2019, 07:50 PM
just a little bit of work today.
Pulled the front valance to get it ready to fix ( should be fun!)
fixed two small dents on the drivers side of the roof, actually primed them too but didn't get a photo of that.
Just a small tip. rattle can primer is the way to go for the personal garage projects with limited air supply for feeding an hvlp. just make sure you are using a good quality product. say no to the rust o crap and duplicolors. I use eurospray 1k. its about 15 bucks a can and is enough to knock out a decent repair area or a couple smaller ones. As before a thin coat of glaze and primer is about all you should ever need on any type of little dings.
ID:	864255   Click image for larger version
ID:	864257   Click image for larger version
ID:	864259   Click image for larger version
ID:	864261   Click image for larger version
