Just bought a 91 525i - Bimmerfest - BMW Forums
E34 (1989 - 1995)
Old 09-09-2019, 04:31 PM
Jojito72 Jojito72 is offline
Mein Auto:
First post, long time lurker. I owned a 2006 328 a while ago but got rid of it because of life. So I finally am at a point to build a fun car. I bought a 1991 525I manual with a m50 today. The body has 300,000 miles engine completely rebuilt about 90,000 ago. The current plan is to fix up the engine to polish everything, fix little issues, and turn it into a weekend/track car. It's rust free runs strong, and shifts clean. I know it needs an o2 sensor from a scan I did and I think there may be a small vacuum issue, it stutters at idle. Is there anything else I should look out for or replace right away? I noticed some oil build up on the front driverside tubing on the engine. I'm looking to do the easy stuff myself but I am also looking for a solid mechanic in the Norfolk area I heard good things about eastern autowerks. Finally, should I just buy a new m50 to build up and eventually swap or work on the current one piece by piece?
Old 09-10-2019, 03:51 PM
Mein Auto:
Follow up post. Just got the car inspected everything was solid. Here's some photos since it was too dark last night. So current plan is to do a turbo build. Redo suspension and coat the underside. Polish up the body and make it a sleeper weekend car. A few questions for you guys. I want to drive the car but I want a completely machined engine are there any good places to look for m50 blocks and trannys so I can build my engine and then swap in the beast once the engine build is done? Also bigger question are there bolt on coilovers kits anywhere? I don't want to weld but I know the front strut is connected to the wheel assembly.
ID:	864211   Click image for larger version
ID:	864213   Click image for larger version
ID:	864215   Click image for larger version
Old 09-11-2019, 05:12 PM
MustangAndy MustangAndy is offline
Mein Auto: 1990 535i
As far as I know every coil over kit requires you to cut the shock tube and weld the front. Rears are bolt in.
As for donor engine and trans check the local pick-n-pulls. I know the yard I go to in Pennsylvania usually has at least one M50 525i in stock. Only downfall is they are autos - never seen a manual car.
http://www.car-part.com/ can search yards that participate in stock - however most of these yards are not u-pulls. you have to call and wait for them to yank the part themselves.
_
'90 535i 5speed (The Project) - '02 Mustang ProCharged 3.8L V6 5speed (The High School Car) - '14 F150 5.0L BOSS 302 V8 4x4
